disable rip aggregation
Description
Disables the RIP aggregation of subnet information on a RIP version 2 (RIPv2) router.
Syntax Description
Default
RIP aggregation is disabled by default.
Usage Guidelines
The disable RIP aggregation command disables the RIP aggregation of subnet information on a switch configured to send RIPv2-compatible traffic. The switch summarizes subnet routes to the nearest class network route. The following rules apply when using RIP aggregation:
  • Within a class boundary, no routes are aggregated.
  • If aggregation is disabled, subnet routes are never aggregated, even when crossing a class boundary.
The following command disables RIP aggregation on the interface:
# disable rip aggregation
Platform Availability
This command is available on all platforms with a Base license or higher as described in the Switch Engine v33.1.1 Licensing Guide document.
